Group: DynoMotion Message: 14821 From: tapiolarikka Date: 5/28/2017
Subject: Getting started with ScreenEditor?
While trying to figure out my Mach lathe threading problem I noticed that KMotionCNC
got two updates that are deal breakers for me, namely G95 and M47
How do I add
-Pages
-Dros/Input boxes that retain/save values between sessions
-buttons
to screens?
I need the above controls to recreate my conversational programming from mach
Rgds,
Tapio
Group: DynoMotion Message: 14824 From: Tom Kerekes Date: 5/30/2017
Subject: Re: Getting started with ScreenEditor?
Hi Tapio,
I assume you mean you are considering switching to KMotionCNC?
Pages: A Screen Script File defines the look of a page.  You can assign an action to a button to load a Screen Script File.
Dros: There are LabelDRO controls where text/numbers can be displayed
Input Boxes: There are Edit Controls that can be read by KFLOP.   See the Add Example in this Video:
https://youtu.be/uQWDttzKuDA?t=12m24s
Retain/Save values between sessions: Currently Values can be defaulted to fixed values and are not retained between sessions.  We will look into saving them to a file.
Buttons: See the example button style.
How do I add
-Pages
-buttons
to screens?
Rgds,
Tapio
Group: DynoMotion Message: 14825 From: Tapio Larikka Date: 5/30/2017
Yes I am strongly looking into it. Its either custom screens or with .net
Input/edit controls:
I watched the video couple of times but I still can't figure out how to put more controls on screen using screen editor.
I need 30 or more input boxes.
I aim to these to generate the g-code files so would the use of KFLOP variables cause unnecessary load on bandwidth?
Rgds,
Tapio
Group: DynoMotion Message: 14827 From: Tom Kerekes Date: 5/30/2017
Hi Tapio,
Currently you cannot add more controls to the screens only re-purpose them.  There are currently 20 spare input boxes.  I suppose we could increase the number of them.  Do you really need more than 30?
I don't think bandwidth would be a problem as things should only need to be transferred when things change or more likely when the User Pushes a button to "Apply" the changes.  Is that how you see it working?
Rgds,
Tapio
Group: DynoMotion Message: 14828 From: Tapio Larikka Date: 5/30/2017
Yes that is how I see it. Or perhaps instead of "Apply" I'd say "PostG-Code" like in mach threading wizard.
The code behind the button should take the values from inputboxes, generate a .ngc file and load it to kmotioncnc/interpreter
The above to be executed in KFLOP feels kind of detour to me
Rgds,
Tapio
Group: DynoMotion Message: 14834 From: Tom Kerekes Date: 6/1/2017
Troy/Tapio/Others,
Here is another Screen Editor Patch
http://dynomotion.com/Software/Patch/FixCheckboxMesg_40SpareEdit_EditPersists_V434i/KMotionCNC.exe
Fix issue with Action Messages to Checkboxes checking/unchecking the checkbox but not changing underlying variable.
Persist Edit Controls between sessions.  Saved to <>\KMotion\Data\EditControlPersist.txt
Increase number of spare edit controls from 20 to 40
Please let me know if there are issues.
Rgds,
Tapio
